Myčka AEG hlásí chybu i10
Dobrý den, myčka AEG Favorit Intensiva po zapnutí programu začne napouštět, po několika cca 2 minutách se rozsvítí chybový kód 10 a myčka se vypustí. Nemáte někdo s touto chybou zkušenost? Díky
pouzi google
If you open a sidepanel and look at the bottom of the machine you see a brown device with a piece of white foam,this is the leak prevention system.
Push foam down and the error code should be cleared.
Make sure you there's no water left on the bottom of machine
his seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks.
